Carburetor Adjustment
  1. Carburetor Adjustment, Install the inductive pickup lead: step 1, image 1 of 2 Carburetor Adjustment, Install the inductive pickup lead: step 1, image 2 of 2
    • Feed the inductive pickup lead wire through one of the two holes in the lower-left corner of the tachometer.
    • Bend the wire around and feed it through the second hole, then pull it tight.
  2. Carburetor Adjustment, Attach the tachometer to the spark plug wire: step 2, image 1 of 2 Carburetor Adjustment, Attach the tachometer to the spark plug wire: step 2, image 2 of 2
    • Clamp the inductive pickup lead alligator clip onto the spark plug wire.
    • Make sure the inductive pickup lead wire is not touching anything except the tachometer.
  3. Carburetor Adjustment, Start the motor: step 3, image 1 of 2 Carburetor Adjustment, Start the motor: step 3, image 2 of 2
    • Wear ear protection for the remainder of the procedure.
    • Start the motor and let it run for two minutes to ensure it reaches operating temperature.
  4. Carburetor Adjustment, Open the choke: step 4, image 1 of 3 Carburetor Adjustment, Open the choke: step 4, image 2 of 3 Carburetor Adjustment, Open the choke: step 4, image 3 of 3
    • Make sure the choke is fully in the open position.
  5. Carburetor Adjustment: step 5, image 1 of 2 Carburetor Adjustment: step 5, image 2 of 2
    • Use a Phillips screwdriver to adjust the carburetor idle screw until the tachometer reads as close to 3100 RPM as possible:
    • Turn the idle screw clockwise to increase RPM
    • Turn the idle screw counterclockwise to decrease RPM
    • Once the idle has been set, shut off the motor and disconnect the tachometer.
The procedure is complete, no further action is required.
2 other people completed this guide.
Sam Omiotek
95,617 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 814
