Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM
  1. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Necessary tools: step 1, image 1 of 2 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Necessary tools: step 1, image 2 of 2
    • A flathead screwdriver
    • A Phillips head screwdriver
    • A T25 torx wrench
    • A Carburetor Adjusting Hex Screwdriver
  2. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: step 2, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: step 2, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Remove the air filter: step 2, image 3 of 3
    • Unclip the air filter cover.
    • Extract the air filter.
    • Filter and carburetor case fixing screws
  3. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: step 3, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: step 3, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Dismantling the carburetor: step 3, image 3 of 3
    • In an anticlockwise movement, unscrew the two fixing screws using a T25 torx key.
    • Remove the two screws and then the filter case.
    • Remove the carburetor.
  4. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: step 4, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: step 4, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburettor disassembly: step 4, image 3 of 3
    • Unhook the accelerator cable. Make sure to remember the location.
    • Extract the transparent fuel return hose.
    • Extract the black fuel inlet hose.
  5. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: step 5, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: step 5, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 1/5: step 5, image 3 of 3
    • Unscrew the two priming pump attachment screws by turning them counterclockwise.
    • Remove the pump.
    • Peel off the pump membrane.
  6. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: step 6, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: step 6, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor Disassembly 2/5: step 6, image 3 of 3
    • Once the pump is disassembled, turn the carburetor 180° to access the four mounting screws.
    • Use a Phillips screwdriver to remove the four membrane cover screws.
  7. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: step 7, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: step 7, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 3/5: step 7, image 3 of 3
    • Remove the membrane cover.
    • Remove the needle lever membrane with the membrane seal.
    • Note: The membrane lever will act on the needle lever.
  8. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: step 8, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: step 8, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 4/5: step 8, image 3 of 3
    • Unscrew the screw that holds the needle lever shaft.
    • CAUTION: Be sure to hold the lever with your thumb to prevent the spring from popping out.
    • Remove the lever, the spring, and the needle.
  9. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: step 9, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: step 9, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor disassembly 5/5: step 9, image 3 of 3
    • Set screw
    • Unscrew the two adjustment screws counterclockwise using the specific adjustment screwdriver.
    • Extract the two screws.
  10. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: step 10, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: step 10, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Cleaning the carburettor in the tank: step 10, image 3 of 3
    • Immerse the carburetor in the ultrasonic bath for 15 to 20 minutes at a temperature between 25 and 35°.
    • Remove the carburetor from the ultrasonic bath.
    • Rinse the carburetor with water, dry it by blowing it out with compressed air.
  11. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 11, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 11, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 11, image 3 of 3
    • Reinstall the spring and needle.
    • Use a flat screwdriver to hold the lever in place.
    • Tighten the screw that holds the axis of the lever using a Phillips screwdriver.
  12. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 12, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 12, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 12, image 3 of 3
    • Reinstall the needle lever membrane and the membrane gasket
    • Reinstall the membrane cover.
    • Tighten the four cover fixing screws using a Phillips screwdriver in a clockwise direction.
  13. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 13, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 13, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 13, image 3 of 3
    • Reinsert the two adjustment screws.
    • Screw them in as far as they will go without forcing them clockwise with the adjustment screwdriver.
    • Pre-adjust the carburettor by unscrewing the two screws one and a half turns counter-clockwise
  14. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 14, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 14, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 14, image 3 of 3
    • Take the pump cover.
    • Reposition the pump membrane and its seal.
    • Replace the pump cover and tighten the two fixing screws clockwise using a Phillips screwdriver.
  15. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 15, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 15, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 15, image 3 of 3
    • Reinstall the black fuel inlet hose.
    • Reinstall the transparent fuel return hose.
    • Reattach the throttle cable.
  16. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 16, image 1 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 16, image 2 of 3 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Carburetor reassembly: step 16, image 3 of 3
    • Insert the two fixing screws in the air filter housing and then in the carburetor body.
    • ATTENTION: Make sure that the fixing screws align with the holes of the gasket.
    • Tighten the fixing screws clockwise using the T25 Torx key.
  17. Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Refitting the air filter: step 17, image 1 of 2 Carburetor cleaning with Ultrasonic Tank - Sterwins PHT25 4CC 55 CM, Refitting the air filter: step 17, image 2 of 2
    • Refit the air filter.
    • Reclips the filter cover.
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 125
All Time: 4,916
