Cardinal Health Vela Ventilator Left Panel Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Power Cable Removal: step 1, image 1 of 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: step 3, image 1 of 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: step 4, image 1 of 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Careful: steps 6-8 are sourced from a guide that's marked as in-progress.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: step 6, image 1 of 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: step 8, image 1 of 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
Tanner Hillman
370 Reputation
3 Guides authored
Cal Poly, Team S7-G22, Paton Spring 2020 Member of Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Member
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 107
