Cardo Packtalk Battery Replacement
  1. Cardo Packtalk Battery Replacement, Remove Case Screws: step 1, image 1 of 1
    • Insert wisdom here.
  2. Cardo Packtalk Battery Replacement, Open Case Carfully: step 2, image 1 of 1
    • Take lower section off first, take care not to strain the battery wires
    • Some people simply cut the old battery wires and heat shrink them to new battery wires to avoid having to re-solder the small solder points on the PCB.
    • If you want to ensure your unit stays waterproof, you can add a thin line of silicone seal around case prior to reassembly
FJrider
300 Reputation
1 Guide authored
2 Guide Comments
Can you recommend a battery to purchase for the Packtalk BOLD? Thanks!
Tony Psaltis - Reply
I can't recommend a particular one, when my Smartpack battery died I cannibalized an OEM battery from a broken Packtalk unit.
Here are a couple batteries on offer from Ebay and Amazon that claim they fit the Packtalk and have some good reviews (do your own research):
-https://www.ebay.com/itm/156144503815?mk...
-https://a.co/d/fuu9s9K
FJrider -
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 157
All Time: 2,997
