Carrera Mario Copter Motherboard Replacement
  1. Carrera Mario Copter Motherboard  Replacement, Battery: step 1, image 1 of 1
    • Flip the quadrocopter over so that the underside of the device is facing up.
    • Unplug the battery cable from the socket on the quadrocopter.
  2. Carrera Mario Copter Motherboard  Replacement: step 2, image 1 of 1
    • Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
  3. Carrera Mario Copter Motherboard  Replacement: step 3, image 1 of 1
    • Pull the battery away from the slot to remove it.
  4. Carrera Mario Copter Motherboard  Replacement, Motherboard: step 4, image 1 of 2 Carrera Mario Copter Motherboard  Replacement, Motherboard: step 4, image 2 of 2
    • Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
    • Remove the entire black circle base and flip it over so you can see the motherboard.
  5. Carrera Mario Copter Motherboard  Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers remove the four white heads wires from the motherboard.
    • Be careful not to cut the wires plugged to the little white heads. Grab onto the plastic connectors if possible.
  6. Carrera Mario Copter Motherboard  Replacement: step 6, image 1 of 2 Carrera Mario Copter Motherboard  Replacement: step 6, image 2 of 2
    • Using the tweezers remove the golden head screws that hold down the motherboard.
    • Hold strong the motherboard and pull up strong the head screws.
    • Be careful not to hurt yourself. You will need to try several times to remove those.
Stephany Martinez
122 Reputation
1 Guide authored
UW Tacoma, Team S1-G6, Rose Fall 2017 Member of UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 590
