Casio A700 Battery Replacement
  1. Casio A700 Battery Replacement, Battery: step 1, image 1 of 3 Casio A700 Battery Replacement, Battery: step 1, image 2 of 3 Casio A700 Battery Replacement, Battery: step 1, image 3 of 3
    • Using a Philips #00 screwdriver, remove the four screws in the rear panel of the watch.
    • Remove the back panel from the watch.
  2. Casio A700 Battery Replacement: step 2, image 1 of 2 Casio A700 Battery Replacement: step 2, image 2 of 2
    • Carefully peel off the sticker placed on top of the battery using tweezers.
  3. Casio A700 Battery Replacement: step 3, image 1 of 3 Casio A700 Battery Replacement: step 3, image 2 of 3 Casio A700 Battery Replacement: step 3, image 3 of 3
    • Use the tweezers to unlatch the lever holding down the battery.
    • Carefully remove the old battery.
  4. Casio A700 Battery Replacement: step 4, image 1 of 2 Casio A700 Battery Replacement: step 4, image 2 of 2
    • Insert the new battery and reengage the lever.
    • Use the tweezers to reset the battery by contacting the battery (+) and the (AC) point at the same time.
  5. Casio A700 Battery Replacement: step 5, image 1 of 1
    • Before reinstalling the back panel, ensure the watch operates and is functional.
  6. Casio A700 Battery Replacement: step 6, image 1 of 2 Casio A700 Battery Replacement: step 6, image 2 of 2
    • Place the back panel into position and use the Philips #00 screwdriver to screw the four screws into place.
Thank you for following my guide on the Casio A700! I hope you found it helpful!
Daniel Solares
160 Reputation
1 Guide authored
3 Guide Comments
Thanks. It would have been better if you'd mentioned the battery type.
It's not a 2032, it's a 1616. I went out and bought some 2032s after reading this and they don't fit.
Misfit the mad - Reply Share
Hey thank you for the guide . one issue the battery is CR 1616 not the one you mentioned.
Why - Reply Share
Nicely done! Very easy to understand and the large photos were very helpful. If you can, correct the part number for the battery then your instructions would be perfect!
Ace - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 138
All Time: 2,098
