Casio CTK-501 Buttons Replacement
  1. Casio CTK-501 Buttons Replacement, Bottom Panel: step 1, image 1 of 2 Casio CTK-501 Buttons Replacement, Bottom Panel: step 1, image 2 of 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Buttons Replacement: step 2, image 1 of 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Buttons Replacement: step 3, image 1 of 2 Casio CTK-501 Buttons Replacement: step 3, image 2 of 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Buttons Replacement, Buttons: step 4, image 1 of 1
    • Remove the nine screws from the brown circuit board that has an attached ribbon, with a #0 Phillips.
  5. Casio CTK-501 Buttons Replacement: step 5, image 1 of 1
    • Remove the circuit board, by pulling upwards.
  6. Casio CTK-501 Buttons Replacement: step 6, image 1 of 1
    • Remove the buttons.
  7. Casio CTK-501 Buttons Replacement: step 7, image 1 of 1
    • Place the new buttons into the slot, and push downward in the slot.
2 other people completed this guide.
Jimmy Winne
578 Reputation
6 Guides authored
Cal Poly, Team 9-16, Amido Fall 2012 Member of Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,290
