Casio CTK-501 Keys Replacement
  1. Casio CTK-501 Keys Replacement, Bottom Panel: step 1, image 1 of 2 Casio CTK-501 Keys Replacement, Bottom Panel: step 1, image 2 of 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: step 2, image 1 of 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: step 3, image 1 of 2 Casio CTK-501 Keys Replacement: step 3, image 2 of 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: step 4, image 1 of 1
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: step 5, image 1 of 1
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: step 6, image 1 of 1
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: step 7, image 1 of 1
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
7 other people completed this guide.
Jimmy Winne
578 Reputation
6 Guides authored
Cal Poly, Team 9-16, Amido Fall 2012 Member of Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Members
6 Guides authored
4 Guide Comments
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Reply
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Reply
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Reply
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 54
All Time: 25,913
