Casio DW-6900 Watchband Replacement
  1. Casio DW-6900 Watchband  Replacement, Watchband: step 1, image 1 of 3 Casio DW-6900 Watchband  Replacement, Watchband: step 1, image 2 of 3 Casio DW-6900 Watchband  Replacement, Watchband: step 1, image 3 of 3
    • There are four screws— two on each side of the watch case.
    • Use the Philllips screwdriver to remove four 4.5 mm screws.
  2. Casio DW-6900 Watchband  Replacement: step 2, image 1 of 2 Casio DW-6900 Watchband  Replacement: step 2, image 2 of 2
    • There are two trunnions on both sides of the watch, and there are four grooves.
    • Use a small flat-blade screwdriver and push inward to remove the trunnion. And remove the strap.
  3. Casio DW-6900 Watchband  Replacement: step 3, image 1 of 1
    • From the bottom of the watch, buckle the case from the main body of the watch by hand.
  4. Casio DW-6900 Watchband  Replacement: step 4, image 1 of 1
    • Align the hole on the side of the case with the button on the watch and put on the new watch case.
  5. Casio DW-6900 Watchband  Replacement: step 5, image 1 of 3 Casio DW-6900 Watchband  Replacement: step 5, image 2 of 3 Casio DW-6900 Watchband  Replacement: step 5, image 3 of 3
    • Thread the trunnion into the small hole on the strap.
    • First, snap one side of the trunnion into the hole of the watch body.
    • Use a flat-blade screwdriver to push the other end of the trunnion into the main body of the watch.
  6. Casio DW-6900 Watchband  Replacement: step 6, image 1 of 2 Casio DW-6900 Watchband  Replacement: step 6, image 2 of 2
    • Screw on the four screws on both sides of the watch.
Shaoguang He
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 109
All Time: 4,267
