Casio Exilim EX-Z850 Outer Case Replacement
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 1 of 3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 2 of 3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: step 1, image 3 of 3
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 1 of 3 Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 2 of 3 Casio Exilim EX-Z850 Outer Case Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Casio Exilim EX-Z850 Outer Case Replacement: step 3, image 1 of 2 Casio Exilim EX-Z850 Outer Case Replacement: step 3, image 2 of 2
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 other people completed this guide.
Logan
313 Reputation
2 Guides authored
Cal Poly, Team 4-38, Regan Winter 2011 Member of Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 3,065
