Casio FX-115ES PLUS Battery Replacement
  1. Casio FX-115ES PLUS Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
  2. Casio FX-115ES PLUS Battery Replacement: step 2, image 1 of 3 Casio FX-115ES PLUS Battery Replacement: step 2, image 2 of 3 Casio FX-115ES PLUS Battery Replacement: step 2, image 3 of 3
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
  3. Casio FX-115ES PLUS Battery Replacement: step 3, image 1 of 1
    • Remove the battery cover.
  4. Casio FX-115ES PLUS Battery Replacement: step 4, image 1 of 1
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
  5. Casio FX-115ES PLUS Battery Replacement: step 5, image 1 of 1
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
  6. Casio FX-115ES PLUS Battery Replacement: step 6, image 1 of 3 Casio FX-115ES PLUS Battery Replacement: step 6, image 2 of 3 Casio FX-115ES PLUS Battery Replacement: step 6, image 3 of 3
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
  7. Casio FX-115ES PLUS Battery Replacement: step 7, image 1 of 1
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
You have successfully replaced a Casio FX-115ES PLUS battery
Rodrigo Lopez
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 114
All Time: 3,836
