Introduction
In the event that your screen is cracked or broken you will need to remove the the motherboard and screen. This guide will show you how.
Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
9 other people completed this guide.
