Casio FX-991ES Plus Battery Replacement
  1. Casio FX-991ES Plus Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the calculator is off. If not, turn it off by pressing the [Shift] button then the [AC] [OFF] button.
  2. Casio FX-991ES Plus Battery Replacement: step 2, image 1 of 1
    • Flip the calculator upside down and lay it on a flat surface.
    • Do not press hard on the calculator to avoid turning it on by mistake.
  3. Casio FX-991ES Plus Battery Replacement: step 3, image 1 of 2 Casio FX-991ES Plus Battery Replacement: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the 1.6 mm screw on the battery cover.
    • Remove the battery cover.
    • Be gentle while unscrewing the cover, to avoid damaging it.
  4. Casio FX-991ES Plus Battery Replacement: step 4, image 1 of 3 Casio FX-991ES Plus Battery Replacement: step 4, image 2 of 3 Casio FX-991ES Plus Battery Replacement: step 4, image 3 of 3
    • Use a spudger to remove the old battery. Insert it in the empty slot to pry out the battery.
    • Do not use a sharp item like a knife.
    • Do not use metal tools, to avoid damaging parts of the battery compartment.
  5. Casio FX-991ES Plus Battery Replacement: step 5, image 1 of 1
    • Place the new battery into the compartment with the positive (+) side facing upwards.
  6. Casio FX-991ES Plus Battery Replacement: step 6, image 1 of 1
    • Attach the battery cover and tighten the screw with a Phillips #0 screwdriver.
  7. Casio FX-991ES Plus Battery Replacement: step 7, image 1 of 1
    • To reset the calculator, press the [ON] button.
    • Press the [SHIFT] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] button to choose "ALL".
    • Press the [=] button to agree.
    • Press the [AC] button
Finish Line
12 other people completed this guide.
Zinab Alhamoud
487 Reputation
1 Guide authored
4 Comments
Thank you so much! God bless you.
Igor Diniz - Reply
Can you send me one please
In Jaigaon india
chandra giri - Reply
La touche ON de ma calculatrice ne fonctionne plus comment faire ?
Emmanuel Prosper - Reply
Past 24 Hours: 26
Past 7 Days: 216
Past 30 Days: 1,010
All Time: 58,638
