Casio FX-991EX Battery Replacement
  1. Casio FX-991EX Battery Replacement, Remove the battery cover: step 1, image 1 of 2 Casio FX-991EX Battery Replacement, Remove the battery cover: step 1, image 2 of 2
    • Remove the battery cover's screw using a Philips #0 screwdriver.
  2. Casio FX-991EX Battery Replacement, Remove the battery: step 2, image 1 of 2 Casio FX-991EX Battery Replacement, Remove the battery: step 2, image 2 of 2
    • Use a spudger to remove the battery using the gap to the right.
    • Don't use sharp objects that may cause harm or damage. The battery can be hard to pop out, but will do so. Dispose of a damaged battery via an e-waste collection site.
  3. Casio FX-991EX Battery Replacement, Replace the battery: step 3, image 1 of 2 Casio FX-991EX Battery Replacement, Replace the battery: step 3, image 2 of 2
    • The FX-991EX uses a 1.5V LR44 battery.
    • Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
    • And the negative side faces the calculator's screen.
  4. Casio FX-991EX Battery Replacement, Screw the cover back on: step 4, image 1 of 1
    • Slot the battery cover back on and screw it down.
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
5 other people completed this guide.
FarmYard Gaming
1,955 Reputation
1 Guide authored
4 Guide Comments
Just discovered during a lecture that my battery has become a spicy pillow - if you're leaving this in storage be careful and monitor it, lest it explode and/or warp the case irreparably.
FarmYard Gaming - Reply Share
Which size of screws
李生山 - Share
I found nothing in the slot. What can i do?
UTL Shaion - Reply Share
Do you see any wires connecting the battery to the circuit board? I don’t see any on mine. Both of ours may be fake lmao
Ivan Liu - Share
Past 24 Hours: 23
Past 7 Days: 174
Past 30 Days: 810
All Time: 23,867
