Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: step 1, image 1 of 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 3, image 1 of 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 3, image 2 of 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: step 4, image 1 of 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 5, image 1 of 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 6, image 1 of 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 7, image 1 of 1
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: step 8, image 1 of 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: step 8, image 2 of 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: step 8, image 3 of 3
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 9, image 1 of 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: step 9, image 2 of 2
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Zack Almeida
392 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 173
