Casio G-Shock G302 Battery Replacement
  1. Casio G-Shock G302 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the four Phillips #00 screws from the back of the watch.
  2. Casio G-Shock G302 Battery Replacement: step 2, image 1 of 1
    • Use a pair of tweezer to remove the metal cover by lifting it.
    • Be careful not tot lose the rubber gasket underneath.
  3. Casio G-Shock G302 Battery Replacement: step 3, image 1 of 1
    • Remove the six Phillips #00 screws from the inside of the watch.
  4. Casio G-Shock G302 Battery Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the protective casing with the battery attached to it.
  5. Casio G-Shock G302 Battery Replacement: step 5, image 1 of 1
    • Use your finger to push the CR2025 Lithium battery out of its protective casing.
6 other people completed this guide.
Filmon Teamrat
307 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 22
Past 7 Days: 177
Past 30 Days: 811
All Time: 66,206
