Casio LK-170 Display Replacement
  1. Casio LK-170 Display Replacement, Display: step 1, image 1 of 1
    • Using JIS-1 screwdriver, remove the seven 11mm screws located on the back of the keyboard.
  2. Casio LK-170 Display Replacement: step 2, image 1 of 1
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip this panel up so that the component board can be seen.
  3. Casio LK-170 Display Replacement: step 3, image 1 of 3 Casio LK-170 Display Replacement: step 3, image 2 of 3 Casio LK-170 Display Replacement: step 3, image 3 of 3
    • We will be removing a total of 26 screws on the component board..
    • First, you must use the PH-1 bit to remove the 17 8mm screws, circled in red.
    • Second, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wire. These screws are circled in orange.
    • Third, using the JIS-1 bit, remove the three 7mm screws on the circuit board.
    • After removing the circuit board, three more screws will be revealed.
    • Using the PH-1 bit, remove the last three 8mm screws, circled in green.
  4. Casio LK-170 Display Replacement: step 4, image 1 of 1
    • Once all the screws have been removed, lift the component board and place it face down on the keys.
    • The component board is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Display Replacement: step 5, image 1 of 1
    • Flip over the component board to reveal the display that is currently connected to a green panel.
  6. Casio LK-170 Display Replacement: step 6, image 1 of 1
    • Remove the display by carefully picking it up with your fingers from the green panel.
Samantha Baker
425 Reputation
4 Guides authored
Cal Poly, Team 13-2, Banghart Winter 2017 Member of Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Members
5 Guides authored
One Comment
Hey, where do you find a replacement lcd?
Albert istvab - Reply
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 19
All Time: 678
