Casio LK-170 Key Replacement
  1. Casio LK-170 Key Replacement, Key: step 1, image 1 of 3 Casio LK-170 Key Replacement, Key: step 1, image 2 of 3 Casio LK-170 Key Replacement, Key: step 1, image 3 of 3
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
  2. Casio LK-170 Key Replacement: step 2, image 1 of 2 Casio LK-170 Key Replacement: step 2, image 2 of 2
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
  3. Casio LK-170 Key Replacement: step 3, image 1 of 2 Casio LK-170 Key Replacement: step 3, image 2 of 2
    • You will be able to pick up the white keys with your hands and remove them.
2 other people completed this guide.
Samantha Baker
443 Reputation
4 Guides authored
Cal Poly, Team 13-2, Banghart Winter 2017 Member of Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Members
5 Guides authored
1 Guide Comment
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 29
All Time: 2,708
