Introduction
For this disassembly we will need a phillips screwdriver 1.5 and a pair of tweezers. Prepare a little container for screws: they are tiny!
This super strong Casio watch is more docile than waht you might think.
We don't need to twist off the front's screws.
It doesn't bite, so let's turn it around
With the phillips screwdriver take off these four screws
Lift up an extremity of the watchstrap and remove the base.
You can use a flat screwdriver to help you
With the tweezers lift the white plastic cover
Be careful to not damage the golden springs!! So take your time
5 other people completed this guide.
3 Comments
cannot see the “Golden Springs”. Where are they? Thank you
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
