Casio WK-220 Black Keys Replacement
  1. Casio WK-220 Black Keys Replacement, White Keys: step 1, image 1 of 2 Casio WK-220 Black Keys Replacement, White Keys: step 1, image 2 of 2
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 Black Keys Replacement: step 2, image 1 of 2 Casio WK-220 Black Keys Replacement: step 2, image 2 of 2
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 Black Keys Replacement: step 3, image 1 of 1
    • Turn device around so keys are face-up
  4. Casio WK-220 Black Keys Replacement: step 4, image 1 of 2 Casio WK-220 Black Keys Replacement: step 4, image 2 of 2
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 Black Keys Replacement: step 5, image 1 of 3 Casio WK-220 Black Keys Replacement: step 5, image 2 of 3 Casio WK-220 Black Keys Replacement: step 5, image 3 of 3
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 Black Keys Replacement: step 6, image 1 of 3 Casio WK-220 Black Keys Replacement: step 6, image 2 of 3 Casio WK-220 Black Keys Replacement: step 6, image 3 of 3
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
  7. Casio WK-220 Black Keys Replacement, Black Keys: step 7, image 1 of 2 Casio WK-220 Black Keys Replacement, Black Keys: step 7, image 2 of 2
    • Remove second white section covering desired black section
    • Remove screws using Phillips #1 screwdriver
    • Push keys away from screws and pull up
  8. Casio WK-220 Black Keys Replacement: step 8, image 1 of 3 Casio WK-220 Black Keys Replacement: step 8, image 2 of 3 Casio WK-220 Black Keys Replacement: step 8, image 3 of 3
    • Use plastic opening tool to pry up black key section
    • Remove black key section
    • Reassemble with new/clean black key section
Alexa
687 Reputation
6 Guides authored
Cal Poly, Team 10-2, Banghart Winter 2017 Member of Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 789
