Casio fx-82MS Button Replacement
  1. Casio fx-82MS Button Replacement, Button: step 1, image 1 of 2 Casio fx-82MS Button Replacement, Button: step 1, image 2 of 2
    • This is the calculator in question.
    • The tools you will need are: a Phillips screwdriver, a spudger and a soldering iron.
    • If you don't have access to a solding iron, you need a stanley knife instead.
  2. Casio fx-82MS Button Replacement: step 2, image 1 of 1
    • Flip over the calculator.
    • Locate the 6 screws on the backside.
    • Remove all six screws.
  3. Casio fx-82MS Button Replacement: step 3, image 1 of 1
    • Once all six screws have been removed, take the back part off of the calculator.
  4. Casio fx-82MS Button Replacement: step 4, image 1 of 2 Casio fx-82MS Button Replacement: step 4, image 2 of 2
    • Locate the rubber contact points.
    • Solder the rubber contact points, while using the spudger to pry the PCB loose.
    • PCB stands for Printed Circuit Board.
    • Toxic gasses might be created. Hence, do this in a well ventilated room.
    • Start with the lower plugs (left on the photo). Gently pry the PCB loose at the same time.
    • For this step a third person is required for safety. One person uses the solder iron, the other one uses the spudger to pry the PCB loose.
    • If you don't have accessibility to a solder iron, use a utility knife to remove the plugs.
  5. Casio fx-82MS Button Replacement: step 5, image 1 of 1
    • After having soldered away all six plugs, lift up the PCB.
    • Flip the board sideways as shown in the picture.
  6. Casio fx-82MS Button Replacement: step 6, image 1 of 2 Casio fx-82MS Button Replacement: step 6, image 2 of 2
    • Remove the rubber mat.
    • Do this carefully, to make sure the buttons stay in their place.
  7. Casio fx-82MS Button Replacement: step 7, image 1 of 2 Casio fx-82MS Button Replacement: step 7, image 2 of 2
    • Replace the broken button.
  8. Casio fx-82MS Button Replacement: step 8, image 1 of 2 Casio fx-82MS Button Replacement: step 8, image 2 of 2
    • Put the rubber mat back in its place.
    • Make sure you push the six slightly damaged plugs through the rubber mat.
  9. Casio fx-82MS Button Replacement: step 9, image 1 of 1
    • Push the PCB back into place.
    • Again make sure you push the slightly damaged plugs through the PCB, to make everything fits perfectly again.
  10. Casio fx-82MS Button Replacement: step 10, image 1 of 1
    • Place the back side of the casing back on top of the front.
  11. Casio fx-82MS Button Replacement: step 11, image 1 of 1
    • Put all six screws back in the back side of the casing.
Finish Line
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 40
All Time: 3,741
