Casio fx-82MS Teardown
  1. Casio fx-82MS Teardown, Remove Case Screws: step 1, image 1 of 3 Casio fx-82MS Teardown, Remove Case Screws: step 1, image 2 of 3 Casio fx-82MS Teardown, Remove Case Screws: step 1, image 3 of 3
    • Remove these screws.
    • 6x Philips #0
  2. Casio fx-82MS Teardown, Split the halves: step 2, image 1 of 3 Casio fx-82MS Teardown, Split the halves: step 2, image 2 of 3 Casio fx-82MS Teardown, Split the halves: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Put the tweezers (in their closed state) into the indentations on the side of the calculator.
    • Slowly open the tweezers, to split the calculator into two halves.
    • On certain build batches of this calculator, glue was used to better hold the halves together. You might have to use a card to split the two pieces.
  3. Casio fx-82MS Teardown, Remove PCB Screws: step 3, image 1 of 2 Casio fx-82MS Teardown, Remove PCB Screws: step 3, image 2 of 2
    • Remove these screws:
    • 4x Philips #0
  4. Casio fx-82MS Teardown, Remove battery terminals from casing: step 4, image 1 of 2 Casio fx-82MS Teardown, Remove battery terminals from casing: step 4, image 2 of 2
    • Use a pair of tweezers to pull the connector out of its holder.
    • Use a screwdriver to lever the connector out of its housing.
  5. Casio fx-82MS Teardown, Remove PCB from case: step 5, image 1 of 3 Casio fx-82MS Teardown, Remove PCB from case: step 5, image 2 of 3 Casio fx-82MS Teardown, Remove PCB from case: step 5, image 3 of 3
    • Insert a spudger in between the PCB and the rubber button holder.
    • Carefully remove the PCB and make sure not to damage the LCD ribbon cable.
  6. Casio fx-82MS Teardown, Remove button holder: step 6, image 1 of 3 Casio fx-82MS Teardown, Remove button holder: step 6, image 2 of 3 Casio fx-82MS Teardown, Remove button holder: step 6, image 3 of 3
    • Peel off the rubber button holder starting in the top left corner.
  7. Casio fx-82MS Teardown, Part List: step 7, image 1 of 2 Casio fx-82MS Teardown, Part List: step 7, image 2 of 2
    • Back part of the case.
    • Front face of the case.
    • PCB with LCD and battery terminals.
    • Rubber button holder.
    • Buttons.
Finish Line
10 other people completed this guide.
Luca Casonato
371 Reputation
1 Guide authored
One Comment
I veganlover loved this guide although it isn’t vegan enough.
Alex Goodwin - Reply
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 78
All Time: 7,719
