Casio fx-9750GII Screen Replacement
  1. Casio fx-9750GII Screen Replacement, Screen: step 1, image 1 of 2 Casio fx-9750GII Screen Replacement, Screen: step 1, image 2 of 2
    • Turn off the calculator and flip it over so the backside is facing up.
    • Slide the battery door off and remove all of the batteries.
  2. Casio fx-9750GII Screen Replacement: step 2, image 1 of 1
    • Use a screwdriver to remove the screws from the back of the calculator.
  3. Casio fx-9750GII Screen Replacement: step 3, image 1 of 1
    • Carefully remove the screw from the battery slot.
  4. Casio fx-9750GII Screen Replacement: step 4, image 1 of 2 Casio fx-9750GII Screen Replacement: step 4, image 2 of 2
    • Remove the back case from the calculator.
    • Be careful of the spring that shows in the second picture. The spring is the convertor of the battery.
  5. Casio fx-9750GII Screen Replacement: step 5, image 1 of 2 Casio fx-9750GII Screen Replacement: step 5, image 2 of 2
    • Remove the screws from the motherboard.
  6. Casio fx-9750GII Screen Replacement: step 6, image 1 of 2 Casio fx-9750GII Screen Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Separate the screen cable from the motherboard using tweezers.
    • Remove the calculator screen.
    • Replace the screen.
  7. Casio fx-9750GII Screen Replacement: step 7, image 1 of 2 Casio fx-9750GII Screen Replacement: step 7, image 2 of 2
    • Replace the board and back cover of the calculator, then install the batteries to test if the new screen works well.
YORK-CHEN-F21SEG[2]
145 Reputation
1 Guide authored
2 Comments
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Happy Zahn - Reply
Where to get the new replacement screen?
Ahmed Farhat - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 55
All Time: 2,223
