Ceiva LF2003 Display Replacement
  1. Ceiva LF2003 Display Replacement, Exterior Frame and Matting: step 1, image 1 of 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Display Replacement: step 2, image 1 of 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Display Replacement: step 3, image 1 of 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Display Replacement: step 4, image 1 of 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Display Replacement, Internal Plastic Screen Frame: step 5, image 1 of 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Display Replacement: step 6, image 1 of 2 Ceiva LF2003 Display Replacement: step 6, image 2 of 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Display Replacement, Display: step 7, image 1 of 3 Ceiva LF2003 Display Replacement, Display: step 7, image 2 of 3 Ceiva LF2003 Display Replacement, Display: step 7, image 3 of 3
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Display Replacement: step 8, image 1 of 1
  9. Ceiva LF2003 Display Replacement: step 9, image 1 of 2 Ceiva LF2003 Display Replacement: step 9, image 2 of 2
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Display Replacement: step 10, image 1 of 3 Ceiva LF2003 Display Replacement: step 10, image 2 of 3 Ceiva LF2003 Display Replacement: step 10, image 3 of 3
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Display Replacement: step 11, image 1 of 1
    • Remove the display assembly from the device.
Casey Glasgow
510 Reputation
5 Guides authored
Cal Poly, Team 9-25, Maness Winter 2014 Member of Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 158
