Ceiva LF2003 Internal Plastic Screen Frame Replacement
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: step 1, image 1 of 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 2, image 1 of 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 3, image 1 of 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 4, image 1 of 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: step 5, image 1 of 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 6, image 1 of 2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: step 6, image 2 of 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
Casey Glasgow
510 Reputation
5 Guides authored
Cal Poly, Team 9-25, Maness Winter 2014 Member of Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 111
