Cen-Tech Seven Function Digital Multimeter Screen Replacement
  1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: step 1, image 1 of 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: step 2, image 2 of 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: step 3, image 1 of 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: step 4, image 2 of 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: step 5, image 1 of 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: step 6, image 1 of 1
    • The screen is located at the top of the device.
  7. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: step 7, image 1 of 1
    • Carefully remove screen from device by lifting upward.
Anna Kihm
938 Reputation
5 Guides authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
6 Guides authored
One Comment
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,414
