Change Packard Bell memory (install)
  1. Change Packard Bell memory (install), Change memory: step 1, image 1 of 3 Change Packard Bell memory (install), Change memory: step 1, image 2 of 3 Change Packard Bell memory (install), Change memory: step 1, image 3 of 3
    • Turn off the laptop completely.
    • Remove the two Phillips # 000 screws and remove the cover.
    • Use your fingers to undo the case on the bottom.
  2. Change Packard Bell memory (install): step 2, image 1 of 3 Change Packard Bell memory (install): step 2, image 2 of 3 Change Packard Bell memory (install): step 2, image 3 of 3
    • To the right of the already installed RAM modules, you will find the brackets that secure the RAM in the bracket. Press the two clips outwards.
    • The Ram chip folds up slightly after unlocking and can then be easily removed. Repeat this process to remove the second RAM as well.
    • Insert the new RAM and press it down with a little pressure, so that the memory is back in the holder.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Sandro
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 16
All Time: 2,517
