Changing the Bath NF SIRYO CHROME thermostatic cartridge
  1. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: step 1, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: step 1, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Access to the thermostatic cartridge: step 1, image 3 of 3
    • WARNING: Before any intervention, make sure that the inverter is in the "OFF" position and close the water supply to the meter.
    • Using a flat screwdriver, unclip the cover to access the handle fixing screw.
    • Unscrew the fixing screw counterclockwise.
  2. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: step 2, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: step 2, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Dismantling the thermostatic handle: step 2, image 3 of 3
    • Before disassembling, check that the mark on the mixer tap is aligned with the "38°" position, then remove the handle.
    • ATTENTION: before extracting the stop ring (38°), check that the two notches are aligned with the mark on the mixer
    • Extract the thrust ring
  3. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: step 3, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: step 3, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Removing the thermostatic cartridge: step 3, image 3 of 3
    • Unscrew the thermostatic cartridge anti-clockwise using a 21 wrench.
    • Extract the cartridge by hand.
  4. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: step 4, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: step 4, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Reassembly: step 4, image 3 of 3
    • Insert the thermostat in the mixer body.
    • Screw in clockwise by hand.
    • Finish the tightening using the spanner 21.
    • ATTENTION: The tightening torque must not exceed 10Nm. We therefore advise you to use a torque wrench so as not to damage the thread of the thermostatic cartridge.
  5. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: step 5, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: step 5, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing and adjusting the stop ring: step 5, image 3 of 3
    • Position the two lines marked on the stop ring facing the point of the mixer tap.
    • Turn on the water supply to proceed with the adjustment step.
    • Turn the diverter handle to run the water, then place a thermometer under the flow to check the correct temperature, which should be 38°.
    • If the temperature is not 38°, adjust by turning the wheel clockwise to decrease the temperature (-°C).
    • And counterclockwise to increase the temperature (+°C).
  6. Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: step 6, image 1 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: step 6, image 2 of 3 Changing the Bath NF SIRYO CHROME thermostatic cartridge, Replacing the handle: step 6, image 3 of 3
    • Align the reference point on the mixer body with the 38° mark on the handle.
    • Tighten the handle fixing screw using a Phillips screwdriver in a clockwise direction.
    • Replace the cover.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 44
All Time: 1,485
