Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME
  1. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Required tools: step 1, image 1 of 1
    • 24mm wrench
    • 21mm wrench
    • Flathead screwdriver
    • Phillips screwdriver
  2. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: step 2, image 1 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: step 2, image 2 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: step 2, image 3 of 3
    • ATTENTION: Before any disassembly of the inverter, remember to close the water supply from the meter.
    • Check that the position of the reverse handle is on 'OFF'
    • Using a small flat screwdriver, unclip the access cover to the screw that holds it in place.
    • Using a Phillips screwdriver, unscrew the fixing screw of the handle.
  3. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Removal of the handle of the inverter: step 3, image 1 of 2 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Removal of the handle of the inverter: step 3, image 2 of 2
    • Unscrew the handle.
  4. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Disassembly of the inverter: step 4, image 1 of 2 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Disassembly of the inverter: step 4, image 2 of 2
    • Using a 24 flat wrench, unscrew the nut counterclockwise.
    • Remove the inverter.
  5. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: step 5, image 1 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: step 5, image 2 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: step 5, image 3 of 3
    • Replacing the inverter
    • Please make sure to properly align the pin of the diverter with the notch indicated by the arrow in the body of the faucet.
  6. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: step 6, image 1 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: step 6, image 2 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: step 6, image 3 of 3
    • Insert the diverter into the body of the faucet.
    • Hand-tighten the inverter mounting nut clockwise.
    • Finish tightening using the 24mm wrench.
  7. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: step 7, image 1 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: step 7, image 2 of 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: step 7, image 3 of 3
    • Align the reference point of the faucet body with the "OFF" marking on the handle.
    • Tighten the fixing screw of the handle using a Phillips screwdriver in a clockwise direction.
    • Put the cover back in place.
Finish Line
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 19
All Time: 483
