Charge 3 Disassembly
  1. Charge 3 Disassembly, Strap Connectors: step 1, image 1 of 3 Charge 3 Disassembly, Strap Connectors: step 1, image 2 of 3 Charge 3 Disassembly, Strap Connectors: step 1, image 3 of 3
    • Remove both T3 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
  2. Charge 3 Disassembly, Display: step 2, image 1 of 3 Charge 3 Disassembly, Display: step 2, image 2 of 3 Charge 3 Disassembly, Display: step 2, image 3 of 3
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Disassembly, Cable Warning: step 3, image 1 of 1
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Disassembly, Battery: step 4, image 1 of 3 Charge 3 Disassembly, Battery: step 4, image 2 of 3 Charge 3 Disassembly, Battery: step 4, image 3 of 3
    • Lift display up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Charge 3 Disassembly, Vibrator Shield: step 5, image 1 of 2 Charge 3 Disassembly, Vibrator Shield: step 5, image 2 of 2
    • Remove both T2 screws
    • Liftoff metal shield
  6. Charge 3 Disassembly, Main Shield: step 6, image 1 of 3 Charge 3 Disassembly, Main Shield: step 6, image 2 of 3 Charge 3 Disassembly, Main Shield: step 6, image 3 of 3
    • Remove two T2 screws
    • Remove T3 screw
  7. Charge 3 Disassembly, Display Connectors: step 7, image 1 of 3 Charge 3 Disassembly, Display Connectors: step 7, image 2 of 3 Charge 3 Disassembly, Display Connectors: step 7, image 3 of 3
    • Liftoff both display connectors
  8. Charge 3 Disassembly, Disconnect Connectors and Altimeter: step 8, image 1 of 2 Charge 3 Disassembly, Disconnect Connectors and Altimeter: step 8, image 2 of 2
    • Disconnect vibrator motor
    • Disconnect heartrate and charging connector
    • Remove altimeter
  9. Charge 3 Disassembly, Side Button and Vibrator: step 9, image 1 of 3 Charge 3 Disassembly, Side Button and Vibrator: step 9, image 2 of 3 Charge 3 Disassembly, Side Button and Vibrator: step 9, image 3 of 3
    • Remove button assembly from case
    • Remove vibrator motor
    • Has a slight bit of adhesive and is magnetic to the case
  10. Charge 3 Disassembly, Motherboard: step 10, image 1 of 2 Charge 3 Disassembly, Motherboard: step 10, image 2 of 2
    • Remove motherboard
    • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
Finish Line
4 other people completed this guide.
ShellingRook27
2,124 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
12 Guides authored
12 Guide Comments
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - Reply
Same, my ifixit pro kit only had a driver for the external screws and did not come with a small enough driver to remove the screws inside the charge 3 unit. I'll need to get the smaller bit from a different kit.
Brian Hall -
Which step in the teardown guide needed the T1 driver?
ShellingRook27 -
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - Reply
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 103
All Time: 11,488
