Charging System reset
  1. Charging System reset, Flip over Roomba: step 1, image 1 of 1
    • Flip over Roomba
  2. Charging System reset, Remove the battery: step 2, image 1 of 3 Charging System reset, Remove the battery: step 2, image 2 of 3 Charging System reset, Remove the battery: step 2, image 3 of 3
    • Depress the tabs on the sides of the battery and lift it out.
    • You may need to use descent force when lifting up.
  3. Charging System reset, Reset the roomba: step 3, image 1 of 2 Charging System reset, Reset the roomba: step 3, image 2 of 2
    • Flip Roomba back over
    • Hold down Roomba's power button for 15 seconds.
  4. Charging System reset, Reinstall the battery.: step 4, image 1 of 3 Charging System reset, Reinstall the battery.: step 4, image 2 of 3 Charging System reset, Reinstall the battery.: step 4, image 3 of 3
    • Flip Roomba back over.
    • Reinsert the battery.
    • Flip Roomba over again.
  5. Charging System reset, Charge and run Roomba: step 5, image 1 of 1
    • Charge Roomba for 16 hours and run on MAX cycle.
    • You should be done!
Perform an uninterrupted 16 hour charge. Then run on MAX cleaning cycle.
Austin Walter
1,273 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 14
All Time: 332
