Chefman RJ38-V2-35 Timer Replacement
  1. Chefman RJ38-V2-35 Timer Replacement, Timer: step 1, image 1 of 1
    • Using the plastic opening tool, pop off each of the four corners on the top silver plate.
  2. Chefman RJ38-V2-35 Timer Replacement: step 2, image 1 of 1
    • Twist off the temperature knob.
  3. Chefman RJ38-V2-35 Timer Replacement: step 3, image 1 of 2 Chefman RJ38-V2-35 Timer Replacement: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four 4mm screws, one in each corner.
    • Also unscrew two 4mm screws.
  4. Chefman RJ38-V2-35 Timer Replacement: step 4, image 1 of 2 Chefman RJ38-V2-35 Timer Replacement: step 4, image 2 of 2
    • Pull off top black cover.
  5. Chefman RJ38-V2-35 Timer Replacement: step 5, image 1 of 3 Chefman RJ38-V2-35 Timer Replacement: step 5, image 2 of 3 Chefman RJ38-V2-35 Timer Replacement: step 5, image 3 of 3
    • Squeeze on plastic pieces holding timer down and push out.
  6. Chefman RJ38-V2-35 Timer Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Pull cable from timer using either hands or tweezers.
Robert Gates
201 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2018 Member of UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 2,581
