ChefsChoice M677 Power Cord Replacement
  1. ChefsChoice M677 Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Keep in mind that there are two DIFFERENT kinds of screws on the base plate:
    • Three 3/8" standard Phillips screws
    • And one 3/8" non-standard triangular Phillips screw.
  2. ChefsChoice M677 Power Cord Replacement: step 2, image 1 of 2 ChefsChoice M677 Power Cord Replacement: step 2, image 2 of 2
    • Remove the "K" rubber pad, then remove the three 3/8" Phillips screws from the baseplate using a #1 Phillips screwdriver.
    • Remove the non-standard Phillips screw.
    • Attempting to remove with a standard Phillips screwdriver will damage the screw head and potentially prevent its removal.
  3. ChefsChoice M677 Power Cord Replacement: step 3, image 1 of 2 ChefsChoice M677 Power Cord Replacement: step 3, image 2 of 2
    • Ensure that the cord is completely unwound from the base plate.
    • Lift the base plate away from the unit.
  4. ChefsChoice M677 Power Cord Replacement: step 4, image 1 of 1
    • Carefully lift the red square protector off the post holding it in place.
  5. ChefsChoice M677 Power Cord Replacement: step 5, image 1 of 3 ChefsChoice M677 Power Cord Replacement: step 5, image 2 of 3 ChefsChoice M677 Power Cord Replacement: step 5, image 3 of 3
    • Remove the two 3/8" Phillips screws using a #1 Phillips screwdriver.
    • Remove the clamp which holds the cord in place.
  6. ChefsChoice M677 Power Cord Replacement: step 6, image 1 of 1
    • Use your hands to pull the black cylinder out from the center of the baseplate. This is the power coupling.
    • Take note of the arrangement of the wires on the coupling device to aid in reassembly. If desired, mark the wires and connectors with different colored tapes.
    • The GREEN wire is the 'ground' or 'protection' wire. It is connected to the center post.
    • The other two wires are both BLACK. You can distinguish them by feel:
    • The smooth wire is the 'neutral' wire.
    • The ribbed wire is the 'hot' wire.
  7. ChefsChoice M677 Power Cord Replacement: step 7, image 1 of 1
    • Remove the connectors (spaded lugs) from the kettle's power coupling by gently pulling on each wire.
  8. ChefsChoice M677 Power Cord Replacement: step 8, image 1 of 1
    • You will need three 16-22 gauge connectors (spaded lugs). The 'gauge' number refers to the wire size the lug connector is designed to fit. These connectors will slip over the contacts on the power coupling.
  9. ChefsChoice M677 Power Cord Replacement: step 9, image 1 of 1
    • On the replacement cord, remove the white, green, and black protective caps. By hand, affix one connector to each cord wire. Follows these steps for each wire:
    • Twist the copper strands on the wire so you can cleanly insert the wire into the connector.
    • Push the copper wiring into the connector until the insulation prevents further insertion.
  10. ChefsChoice M677 Power Cord Replacement: step 10, image 1 of 3 ChefsChoice M677 Power Cord Replacement: step 10, image 2 of 3 ChefsChoice M677 Power Cord Replacement: step 10, image 3 of 3
    • Using the multi-tool in crimper mode (or a special crimping tool), apply pressure on the connector 'shank' where the wire was inserted.
    • The ridge that you achieve by crimping should look the same as the connector shown here on the green wire. Give the connector a gentle pull to confirm it is well connected to the wire (it should not slip off).
    • Repeat steps 10 and 11 for the remaining two wires requiring connectors.
  11. ChefsChoice M677 Power Cord Replacement: step 11, image 1 of 3 ChefsChoice M677 Power Cord Replacement: step 11, image 2 of 3 ChefsChoice M677 Power Cord Replacement: step 11, image 3 of 3
    • Thread the replacement cord through the opening closest to the cord symbol on the bottom of the baseplate.
    • Insert the cord until the green, white, and black wires are pushed all the way through.
  12. ChefsChoice M677 Power Cord Replacement: step 12, image 1 of 2 ChefsChoice M677 Power Cord Replacement: step 12, image 2 of 2
    • Reinsert the power coupling (the black cylinder) through the baseplate.
    • Slide the connectors into the exposed metal prongs protruding from the power coupling. This may require a little force because the connection is a tight fit.
    • Reattach the black plastic oval piece in order to secure and stabilize the cord wires.
  13. ChefsChoice M677 Power Cord Replacement: step 13, image 1 of 1
    • Replace the red square protector on top of the wiring system.
  14. ChefsChoice M677 Power Cord Replacement: step 14, image 1 of 2 ChefsChoice M677 Power Cord Replacement: step 14, image 2 of 2
    • Align the two parts of the baseplate as shown in these two photos.
    • Push or pull on the cord as needed to ensure a stable fit before inserting the screws.
  15. ChefsChoice M677 Power Cord Replacement: step 15, image 1 of 3 ChefsChoice M677 Power Cord Replacement: step 15, image 2 of 3 ChefsChoice M677 Power Cord Replacement: step 15, image 3 of 3
    • Align the holes on the two halves of the baseplate precisely.
    • Using a #1 Phillips head screwdriver, tighten the three 3/8" Philips head screws in the holes located along the outer edge of the base plate.
    • Using a #1 TRIANGULAR head screwdriver, tighten the 3/8" TRIANGULAR Phillips screw at the center of the base plate.
  16. ChefsChoice M677 Power Cord Replacement: step 16, image 1 of 1
    • Your baseplate with the new cord attached should look similar to the one shown in the photo.
Finish Line
4 other people completed this guide.
Randy Fromm
679 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 70
All Time: 3,915
