Christmas Battery Box USB Port Repair
  1. Christmas Battery Box USB Port Repair, Christmas Battery Box USB Port Repair: step 1, image 1 of 3 Christmas Battery Box USB Port Repair, Christmas Battery Box USB Port Repair: step 1, image 2 of 3 Christmas Battery Box USB Port Repair, Christmas Battery Box USB Port Repair: step 1, image 3 of 3
    • Place both thumbs, one on each side of the front cover of the battery box, and push the plastic cover upwards until it slides off the box.
    • Place the cover to the side.
  2. Christmas Battery Box USB Port Repair: step 2, image 1 of 2 Christmas Battery Box USB Port Repair: step 2, image 2 of 2
    • Pry each battery out with your fingernails, or use any flathead tool like a spudger or flathead screwdriver to remove batteries.
    • Place batteries to the side.
  3. Christmas Battery Box USB Port Repair: step 3, image 1 of 3 Christmas Battery Box USB Port Repair: step 3, image 2 of 3 Christmas Battery Box USB Port Repair: step 3, image 3 of 3
    • There will be a plastic cover over a green circuit board. Use a spudger or appropriate size screwdriver to wedge in between the cover and the board. Lift up the plastic cover with your tool of choice until the cover is pried off gently.
    • There will be a wire connecting the circuit board to the battery port. Use a spudger or screwdriver to pry the circuit board out of the box and place it to the side with the wire still intact.
  4. Christmas Battery Box USB Port Repair: step 4, image 1 of 1
    • Put on safety glasses while soldering. This will protect your eyes from any potential tiny particles of soldered metal that may break off during the soldering process.
    • When handling the soldering kit, be careful not to touch the hot iron with your hands to avoid any burns.
    • Take out the soldering metal kit. Follow closely the instructions of your soldering kit and solder the USB port.
    • Heat the soldering iron and melt some solder onto the tip. Touch the tip to the wire end and the battery terminal at the same time and let the solder flow into the joint. Be careful not to overheat the battery or damage it.
    • Repeat for the other wire and terminal.
  5. Christmas Battery Box USB Port Repair: step 5, image 1 of 2 Christmas Battery Box USB Port Repair: step 5, image 2 of 2
    • Return the circuit board to the battery box.
    • Grab the circuit board. Place it inside the box and press down.
    • Place the plastic cover over the circuit board and snap back into place.
  6. Christmas Battery Box USB Port Repair: step 6, image 1 of 3 Christmas Battery Box USB Port Repair: step 6, image 2 of 3 Christmas Battery Box USB Port Repair: step 6, image 3 of 3
    • Return all 3 batteries back into their correct places.
    • Make sure the positive ends on the batteries are aligned opposite the springs and the negative ends are aligned to the springs for correct electrical connectivity.
    • Place the plastic cover over the box and slide it down until it snaps closed with your thumbs.
    • After this step, the repair is done. Try turning the on switch of your lights, and test out your working lights.
    • If the lights are still lagging or not lighting, double-check if the batteries are placed in their correct placements. Another option is to follow steps 1 through 6 again.
Finish Line
Eleonora Polovina
149 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 6
Past 30 Days: 22
All Time: 582
