Chromebook Pixel (2013) Battery Replacement
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: step 1, image 1 of 2 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: step 1, image 2 of 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: step 2, image 1 of 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: step 2, image 2 of 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: step 2, image 3 of 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: step 3, image 1 of 2 Chromebook Pixel (2013) Battery Replacement, Pop it open: step 3, image 2 of 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): step 4, image 1 of 2 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): step 4, image 2 of 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: step 5, image 1 of 1
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: step 6, image 1 of 1
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: step 7, image 1 of 2 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: step 7, image 2 of 2
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: step 8, image 1 of 1
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: step 9, image 1 of 2 Chromebook Pixel (2013) Battery Replacement, Install the new battery: step 9, image 2 of 2
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
9 other people completed this guide.
Kevin Fessler
1,830 Reputation
4 Guides authored
2 Guide Comments
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - Reply
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 47
All Time: 7,823
