Chromebook x360 14-da0011dx Fan Replacement
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: step 1, image 1 of 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: step 2, image 1 of 2 Chromebook x360 14-da0011dx Fan Replacement: step 2, image 2 of 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: step 3, image 1 of 3 Chromebook x360 14-da0011dx Fan Replacement: step 3, image 2 of 3 Chromebook x360 14-da0011dx Fan Replacement: step 3, image 3 of 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: step 4, image 1 of 2 Chromebook x360 14-da0011dx Fan Replacement, Battery: step 4, image 2 of 2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: step 5, image 1 of 2 Chromebook x360 14-da0011dx Fan Replacement: step 5, image 2 of 2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: step 6, image 1 of 1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: step 7, image 1 of 1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: step 8, image 1 of 2 Chromebook x360 14-da0011dx Fan Replacement: step 8, image 2 of 2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 175
