Chromecast Case Replacement
  1. Chromecast Case Replacement, Case: step 1, image 1 of 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Case Replacement: step 2, image 1 of 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Case Replacement: step 3, image 1 of 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Case Replacement: step 4, image 1 of 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Case Replacement: step 5, image 1 of 2 Chromecast Case Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
5 other people completed this guide.
Cameron Heiges
688 Reputation
3 Guides authored
IUPUI, Team S5-G6, Baechle Spring 2018 Member of IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Members
6 Guides authored
1 Guide Comment
que hacer si el pin de centro de carga se despredio como pegarlo o soldarlo?
edgar arreola - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,799
