Chromecast Power Button Replacement
  1. Chromecast Power Button Replacement, Case: step 1, image 1 of 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Power Button Replacement: step 2, image 1 of 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Power Button Replacement: step 3, image 1 of 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Power Button Replacement: step 4, image 1 of 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Power Button Replacement: step 5, image 1 of 2 Chromecast Power Button Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Power Button Replacement, Power Button: step 6, image 1 of 1
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
2 other people completed this guide.
Cameron Heiges
688 Reputation
3 Guides authored
IUPUI, Team S5-G6, Baechle Spring 2018 Member of IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,099
