Chromo Noria Battery Replacement
  1. Chromo Noria Battery Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Battery Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Battery Replacement, Back Panel: step 1, image 3 of 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Battery Replacement: step 2, image 1 of 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Battery Replacement, Battery: step 3, image 1 of 3 Chromo Noria Battery Replacement, Battery: step 3, image 2 of 3 Chromo Noria Battery Replacement, Battery: step 3, image 3 of 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Battery Replacement: step 4, image 1 of 3 Chromo Noria Battery Replacement: step 4, image 2 of 3 Chromo Noria Battery Replacement: step 4, image 3 of 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Battery Replacement: step 5, image 1 of 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
Kevin Nguyen
159 Reputation
1 Guide authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 8
All Time: 529
