Chromo Noria Motherboard Replacement
  1. Chromo Noria Motherboard Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Motherboard Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Motherboard Replacement: step 2, image 1 of 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Motherboard Replacement, Battery: step 3, image 1 of 3 Chromo Noria Motherboard Replacement, Battery: step 3, image 2 of 3 Chromo Noria Motherboard Replacement, Battery: step 3, image 3 of 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Motherboard Replacement: step 4, image 1 of 3 Chromo Noria Motherboard Replacement: step 4, image 2 of 3 Chromo Noria Motherboard Replacement: step 4, image 3 of 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Motherboard Replacement: step 5, image 1 of 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Motherboard Replacement, Camera: step 6, image 1 of 2 Chromo Noria Motherboard Replacement, Camera: step 6, image 2 of 2
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Motherboard Replacement: step 7, image 1 of 2 Chromo Noria Motherboard Replacement: step 7, image 2 of 2
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Motherboard Replacement: step 8, image 1 of 2 Chromo Noria Motherboard Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Motherboard Replacement, Speaker: step 9, image 1 of 1
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Motherboard Replacement: step 10, image 1 of 2 Chromo Noria Motherboard Replacement: step 10, image 2 of 2
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Motherboard Replacement: step 11, image 1 of 1
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Motherboard Replacement, Motherboard: step 12, image 1 of 2 Chromo Noria Motherboard Replacement, Motherboard: step 12, image 2 of 2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Motherboard Replacement: step 13, image 1 of 1
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Motherboard Replacement: step 14, image 1 of 3 Chromo Noria Motherboard Replacement: step 14, image 2 of 3 Chromo Noria Motherboard Replacement: step 14, image 3 of 3
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Motherboard Replacement: step 15, image 1 of 1
    • Desolder the eight connections.
  16. Chromo Noria Motherboard Replacement: step 16, image 1 of 1
    • Lift the motherboard to remove.
Nick Rohn
475 Reputation
3 Guides authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 250
