Chromo Noria Speaker Replacement
  1. Chromo Noria Speaker  Replacement, Back Panel: step 1, image 1 of 3 Chromo Noria Speaker  Replacement, Back Panel: step 1, image 2 of 3 Chromo Noria Speaker  Replacement, Back Panel: step 1, image 3 of 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Speaker  Replacement: step 2, image 1 of 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Speaker  Replacement, Speaker: step 3, image 1 of 1
    • Using your spudger tool, remove speaker from the backboard.
  4. Chromo Noria Speaker  Replacement: step 4, image 1 of 2 Chromo Noria Speaker  Replacement: step 4, image 2 of 2
    • Using the spudger tool, detach the speaker from the back of the screen.
  5. Chromo Noria Speaker  Replacement: step 5, image 1 of 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a Soldering Iron, desolder both wires from the motherboard.
Ryan Rho
201 Reputation
2 Guides authored
Baylor, Team 5-6, Williams Fall 2016 Member of Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 155
