Chumby One Speaker Replacement
  1. Chumby One Speaker Replacement, Chassis: step 1, image 1 of 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Speaker Replacement: step 2, image 1 of 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Speaker Replacement: step 3, image 1 of 1
    • Remove the back and bottom cover.
  4. Chumby One Speaker Replacement: step 4, image 1 of 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Speaker Replacement: step 5, image 1 of 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Speaker Replacement: step 6, image 1 of 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Speaker Replacement: step 7, image 1 of 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Speaker Replacement: step 8, image 1 of 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Speaker Replacement: step 9, image 1 of 1
    • Remove the inner components from the outer shell.
  10. Chumby One Speaker Replacement, Speaker: step 10, image 1 of 1
    • Remove the speaker wire connector from the motherboard.
  11. Chumby One Speaker Replacement: step 11, image 1 of 2 Chumby One Speaker Replacement: step 11, image 2 of 2
    • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
  12. Chumby One Speaker Replacement: step 12, image 1 of 1
    • Remove the speaker.
Jordan Houchins
401 Reputation
4 Guides authored
IUPUI, Team S3-G3, Baechle Spring 2017 Member of IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 176
