Cineyo BT-03 Device Speaker Replacement
  1. Cineyo BT-03 Device Speaker Replacement, Cineyo BT-03 Device Disassembly: step 1, image 1 of 3 Cineyo BT-03 Device Speaker Replacement, Cineyo BT-03 Device Disassembly: step 1, image 2 of 3 Cineyo BT-03 Device Speaker Replacement, Cineyo BT-03 Device Disassembly: step 1, image 3 of 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Speaker Replacement: step 2, image 1 of 2 Cineyo BT-03 Device Speaker Replacement: step 2, image 2 of 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Speaker Replacement: step 3, image 1 of 3 Cineyo BT-03 Device Speaker Replacement: step 3, image 2 of 3 Cineyo BT-03 Device Speaker Replacement: step 3, image 3 of 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Speaker Replacement: step 4, image 1 of 3 Cineyo BT-03 Device Speaker Replacement: step 4, image 2 of 3 Cineyo BT-03 Device Speaker Replacement: step 4, image 3 of 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Speaker Replacement: step 5, image 1 of 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Speaker Replacement: step 6, image 1 of 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Speaker Replacement, Speaker: step 7, image 1 of 1
    • Separate the wires so that each white cap distinctly has a single red and single black wire coming out of it.
    • This is to make it safe and easy to disconnect the wires.
  8. Cineyo BT-03 Device Speaker Replacement: step 8, image 1 of 1
    • Disconnect the two sets of wires by pulling on the wires until the white cap detaches from the circuit board.
    • Make sure to leave the white casing attached to the circuit board.
  9. Cineyo BT-03 Device Speaker Replacement: step 9, image 1 of 2 Cineyo BT-03 Device Speaker Replacement: step 9, image 2 of 2
    • Detach the solder points on each gold speaker in order to release and remove them.
    • For help soldering, please review iFixit's Soldering Guide.
Rene Klopf
463 Reputation
4 Guides authored
Baylor, Team 8-3, Whitney Spring 2017 Member of Baylor, Team 8-3, Whitney Spring 2017
BU-WHITNEY-S17S8G3
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 170
