Cirago M9030 Button Module Replacement
  1. Cirago M9030 Button Module Replacement, Cover: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Button Module Replacement: step 2, image 1 of 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Button Module Replacement: step 3, image 1 of 2 Cirago M9030 Button Module Replacement: step 3, image 2 of 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Button Module Replacement, Hard Drive: step 4, image 1 of 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Button Module Replacement: step 5, image 1 of 3 Cirago M9030 Button Module Replacement: step 5, image 2 of 3 Cirago M9030 Button Module Replacement: step 5, image 3 of 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Button Module Replacement: step 6, image 1 of 3 Cirago M9030 Button Module Replacement: step 6, image 2 of 3 Cirago M9030 Button Module Replacement: step 6, image 3 of 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Button Module Replacement, IDE Connector: step 7, image 1 of 2 Cirago M9030 Button Module Replacement, IDE Connector: step 7, image 2 of 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Button Module Replacement: step 8, image 1 of 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Button Module Replacement: step 9, image 1 of 2 Cirago M9030 Button Module Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Button Module Replacement: step 10, image 1 of 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Button Module Replacement: step 11, image 1 of 2 Cirago M9030 Button Module Replacement: step 11, image 2 of 2
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
    • Completely remove the IDE connector from the device.
  12. Cirago M9030 Button Module Replacement, Motherboard: step 12, image 1 of 2 Cirago M9030 Button Module Replacement, Motherboard: step 12, image 2 of 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
  13. Cirago M9030 Button Module Replacement, Button Module: step 13, image 1 of 1
    • Set aside the front cover.
    • Flip over the motherboard.
    • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
  14. Cirago M9030 Button Module Replacement: step 14, image 1 of 3 Cirago M9030 Button Module Replacement: step 14, image 2 of 3 Cirago M9030 Button Module Replacement: step 14, image 3 of 3
    Tool used on this step:
    Buy
    • Using the tweezers, lift up the button module to a 180 degree angle.
    • Leave the button module attached by the ribbon.
    • Flip over the motherboard with the button module still attached.
  15. Cirago M9030 Button Module Replacement: step 15, image 1 of 3 Cirago M9030 Button Module Replacement: step 15, image 2 of 3 Cirago M9030 Button Module Replacement: step 15, image 3 of 3
    • Fold the button module over the motherboard.
    • Using the tweezers, remove the ribbon pin.
    • The ribbon pin should snap completely off of the motherboard.
  16. Cirago M9030 Button Module Replacement: step 16, image 1 of 2 Cirago M9030 Button Module Replacement: step 16, image 2 of 2
    • The ribbon should easily detach from the motherboard.
Ryan Sutardji
171 Reputation
7 Guides authored
Cal Poly, Team 1-4, Regan SU 2012 Member of Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,128
