Circular Saw Blade Replacement
  1. Circular Saw Blade Replacement, Blade: step 1, image 1 of 2 Circular Saw Blade Replacement, Blade: step 1, image 2 of 2
    • Unplug your circular saw or remove the battery before replacing the blade!
  2. Circular Saw Blade Replacement: step 2, image 1 of 3 Circular Saw Blade Replacement: step 2, image 2 of 3 Circular Saw Blade Replacement: step 2, image 3 of 3
    • Press and hold down the blade lock button to keep the blade from turning while you loosen it.
    • Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
    • Your circular saw may already come with a hex key.
  3. Circular Saw Blade Replacement: step 3, image 1 of 2 Circular Saw Blade Replacement: step 3, image 2 of 2
    • Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
  4. Circular Saw Blade Replacement: step 4, image 1 of 2 Circular Saw Blade Replacement: step 4, image 2 of 2
    • Remove the arbor washer.
  5. Circular Saw Blade Replacement: step 5, image 1 of 3 Circular Saw Blade Replacement: step 5, image 2 of 3 Circular Saw Blade Replacement: step 5, image 3 of 3
    • Completely retract the blade guard.
    • You can hold the blade guard in place with a clamp while you change the blade.
  6. Circular Saw Blade Replacement: step 6, image 1 of 3 Circular Saw Blade Replacement: step 6, image 2 of 3 Circular Saw Blade Replacement: step 6, image 3 of 3
    • Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
    • Slowly slide out the blade.
    • Use extreme caution when handling the blade!
  7. Circular Saw Blade Replacement: step 7, image 1 of 1
    • When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
3 other people completed this guide.
Craig Lloyd
41,331 Reputation
82 Guides authored
3 Guide Comments
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
F6 Adhesive Tape - Reply
I think you need a cutting disc in your circular saw
to cut concrete.
Toon Konings - Reply
the problem is that cutting concrete with a concrete disk produces a lot of concrete dust. It will kill your machine. It is not possible to stop the dust by pouring water as you would do with a tile cutting machine.
vief - Reply
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 151
All Time: 10,424
