Clarinet Cork Replacement
  1. Clarinet Cork Replacement, Cork: step 1, image 1 of 1
    • Using pliers, remove the old cork by pinching it off.
    • Make sure not to push too hard with the pliers, as you can crack or chip the structure.
  2. Clarinet Cork Replacement: step 2, image 1 of 1
    • Clean the joint with soap and water
  3. Clarinet Cork Replacement: step 3, image 1 of 1
    • Measure the width of the tenon joint.
    • Only measure the area where the cork will lie, not the entire joint.
  4. Clarinet Cork Replacement: step 4, image 1 of 1
    • Cut the new cork to match the width of the tenon joint.
  5. Clarinet Cork Replacement: step 5, image 1 of 1
    • Peel off the backside of the cork to reveal the adhesive.
  6. Clarinet Cork Replacement: step 6, image 1 of 1
    • Wrap the cork around the joint.
  7. Clarinet Cork Replacement: step 7, image 1 of 1
    • Sand the cork with sandpaper until the cork is smooth.
  8. Clarinet Cork Replacement: step 8, image 1 of 1
    • Apply cork grease on the new cork.
  9. Clarinet Cork Replacement: step 9, image 1 of 1
    • Slowly twist and slide the joint back together.
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
9 other people completed this guide.
Hill Xiong
306 Reputation
1 Guide authored
4 Guide Comments
Where do you buy the corks from? Could you post a link to them?
Joshua Leung - Reply Share
Make sure to use sandpaper with around 60 - 80 grit
[deleted] - Reply Share
Wat if the cork strips don't have adhesive.wat do I use
kendall mckenzie - Reply Share
Contact cement. See this article.
David Willett - Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 117
All Time: 16,009
