Classen Over Seeder TS20HD 2012 Belt Guard Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Safety precautions: step 1, image 1 of 2 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, ensure that the machine is powered down and cool to the touch.
    • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Classen Over Seeder TS20HD 2012 Belt Guard Replacement: step 2, image 1 of 1
    • To prevent the over seeder from rolling during service, place wheel chocks behind a rear wheel.
  3. Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Tilt the over seeder: step 3, image 1 of 2 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Tilt the over seeder: step 3, image 2 of 2
    • Push down on the main handle to tilt the over seeder back on its rear wheels.
    • Place some weights on the handle, or tie the handle down, to prevent the machine from falling forward.
  4. Classen Over Seeder TS20HD 2012 Belt Guard Replacement: step 4, image 1 of 1
    • Place a wheel chock in front of a rear tire to keep the machine in place.
  5. Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Unscrew the belt guard: step 5, image 1 of 3 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Unscrew the belt guard: step 5, image 2 of 3 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Unscrew the belt guard: step 5, image 3 of 3
    • Remove the four lock nuts securing the belt guard:
    • Two 1/2" lock nuts
    • Two 7/16" lock nuts
    • These lock nuts are recessed and require a socket extension to access.
    • Use box wrenches to hold the corresponding bolts in place as you loosen and remove the nuts.
  6. Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Remove the belt guard: step 6, image 1 of 3 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Remove the belt guard: step 6, image 2 of 3 Classen Over Seeder TS20HD 2012 Belt Guard Replacement, Remove the belt guard: step 6, image 3 of 3
    • Remove the belt guard.
Arthur Shi
281,620 Reputation
584 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 19
