Introduction
Follow this guide to replace the lower V-belt on a 2018 Classen Sod Cutter model HSC18AHD.
Use a 1/2 inch socket to remove the first two bolts from the belt shield.
Use a 1/2Â inch socket to remove the third bolt from the belt shield.
Use your fingers to roll the belt. If you cannot twist the belt more than a quarter turn, the belt is sufficiently tensioned. If the belt is too loose, set the idler pulley lower to tension the belt more.
Use a 3/4 inch socket to remove the bolt securing the eccentric arm to the blade arm.
Move the cutter blade handle back to disengage the blade drive and relieve tension on the V-belt.
2 other people completed this guide.
