Classen Sod Cutter SC18AHDCA 2019 Blade Replacement
  1. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Safety precautions: step 1, image 1 of 2 Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, make sure that the machine is turned off.
    • For safety purposes, disconnect the spark plug.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement: step 2, image 1 of 1
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Unscrew the blade: step 3, image 1 of 2 Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Unscrew the blade: step 3, image 2 of 2
    • Use a 1/2" socket wrench to remove the six 1 inch-long bolts securing both ends of the blade. You may need to use a 1/2" combination wrench to hold the nuts in place.
  4. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Remove the blade: step 4, image 1 of 2 Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Remove the blade: step 4, image 2 of 2
    • The blade can be very sharp! Do not handle the blade from the cutting edge.
    • Grasp the back of the blade and slide it away from the mount.
    • Remove the blade.
2 other people completed this guide.
Arthur Shi
281,620 Reputation
584 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,676
