Classique 087CQA Heating Element Replacement
  1. Classique 087CQA Heating Element Replacement, Heating Element: step 1, image 1 of 1
    • Begin with the side with switches
  2. Classique 087CQA Heating Element Replacement: step 2, image 1 of 2 Classique 087CQA Heating Element Replacement: step 2, image 2 of 2
    • Remove the Phillips PH0 bit
    • Insert the bit into the screwdriver
  3. Classique 087CQA Heating Element Replacement: step 3, image 1 of 1
    • Unscrew the shell screw (1) with the screw driver
    • 5mm Phillips flat-head screw
  4. Classique 087CQA Heating Element Replacement: step 4, image 1 of 1
    • Flip the hair dryer over to the side without switches
  5. Classique 087CQA Heating Element Replacement: step 5, image 1 of 1
    • Unscrew the shell screw (1) with the screwdriver
  6. Classique 087CQA Heating Element Replacement: step 6, image 1 of 2 Classique 087CQA Heating Element Replacement: step 6, image 2 of 2
    • Remove the bit from the screwdriver and insert the Phillips PH2 bit
  7. Classique 087CQA Heating Element Replacement: step 7, image 1 of 1
    • Unscrew the remaining shell screws (5) with the screwdriver
    • 15mm Phillips round-head screws
  8. Classique 087CQA Heating Element Replacement: step 8, image 1 of 2 Classique 087CQA Heating Element Replacement: step 8, image 2 of 2
    • Gently pull the two sides apart
    • Separate each side
  9. Classique 087CQA Heating Element Replacement: step 9, image 1 of 1
    • Remove front grill
  10. Classique 087CQA Heating Element Replacement: step 10, image 1 of 2 Classique 087CQA Heating Element Replacement: step 10, image 2 of 2
    • Pull up and remove the heating element assembly
  11. Classique 087CQA Heating Element Replacement: step 11, image 1 of 1
    • Remove the outer sleeve and replace the heating element
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 32
All Time: 931
